windreef
Hello everyone,
I imported inv2010 a disk cam (step) created with a software specific to the study of cams. However, this software generates the surface of the cam with many small faces due to the precise setting of the cam itself. the problem arises from the fact that in order to try the cinematism of the cam in in inv I have to use the transitory bond that not from the possibility to select more than one (it would be impossible however because they are thousands).There is a command to unite all these faces in a single one for having a unique selection of all the cam profile.
Thank you very much
Thank you very much
