info creation asola with positioning on sketch at points
D4n13l
Hello everyone
I use the 2013 version of inventor and I wanted to create an asola as sheet punch so that it automatically takes the points present a sketch, to understand how when you go to create holes.
Does anyone know if it is possible to do so?
Thank you in advance
you will have to create the sketch of the asola by binding it to the points.
If I understood the need well. . .
pdf allego with instruction for creating a punch
I also attach the punzone file already made
ps. the file "_asola_.pdf" must be renamed in _asola_.ide (extension of the punch)
