strangelittle_girl
I address the 3dvia composers to have an info.
I would like to know if there is a way directly with 3dvia or with the help of other sw, which allows the nomenclature and the cataloguing of the views generated in 3dvia. I'll explain better.
working inside d 3dvia composed with big assemblies you go to generate a set of images and views of the product. often happens that these are so many. the difficulty you encounter is to go to take every view and save it by giving it a sensible name that allows you to recover it in a short time and if necessary. I then wondered if you set up a setting that allows the nomenclature and saving the views automatically in a default folder.
I hope I've been clear. .
Thank you all! :wink:
