info inventor
  • Thread starter Thread starter Marcoenotek
Supposing you used the program as you should, the holes will be executed with the hole command and then created a repetition.
double click on the hole command and you do the desired thread.
come c
as with all the parametric cads....good or bad, or you have a guud sketch or have a repetition on which you act the feautures.
as c
I've seen things that you humans...
In the meantime, we expect confident feedback that has been made to us.
Sorry, but the question is not clear to me: are there already the "prefori" and you need to "dress" with a thread? In this case I would recommend that you use the threaded hole command directly. in the specific, if the holes have all a parallel axis and same diameter, it is advisable to do a sketch and insert the points where the holes serve and do everything in a single processing
