info rotation constraint
demaio1982
Hello everyone I am a biomedical engineering student, I am approaching with ansys 12 apdl . I noticed that when I go to bind wrapped there is the rot displacement and wrapped up by what it depends, someone can explain it to me?! !
solid elements have nodes characterized by 3 degrees of freedom (positions in space): ux, uy, uz
shell elements (shells) have knots characterized by 6 degrees of freedom: positions ux, uy, uz and rx rotations, ry, rz.
because you find it on school books.
my problem is this, it is also very simple , I created a straight tilted in the x-y plane is emaciated with the link1 element in ansys 12.1 I simply wanted to bind by setting up a keypoint by binding the direction y , x and the rotation around the z axis and the other keypoint apply a force parallel to the straight . but it does not allow me to bind the rotations I tried to use the beam elements too
thanks for the help
