info telaio?
  • Thread starter Thread starter l0r3nzo
l0r3nzo
Hello.
Sorry if my discussion can be a little banal but I can't find a response on the web...
So I have this villa that I have to pull up with a frame only that the walls are not perpendicular and so I can't place the pillar circled up.
that is, having two different axes of direction, how can I do that pillar?
I attach image for clarity.
Thank you all.
http://yfrog.com/0u80238279j
the two outer sides of the pillar must be parallel to the two walls.
qindi you will not have a section of the rectangular shape pillar, but will be in the form of irregular "quadrilareto".
correctly setting the pillar section, you can get a rectangle trapeze (only one oblique side)
