info versione 7
  • Thread starter Thread starter NautaAlberto
NautaAlberto
good evening, someone to ask for info about this version, unfortunately the owner last year had covid, and I stayed only from today to tomorrow trying to move on the company, in fixing the pc I would not like to have made some cable, the software works , opens the files , import or export the files, but if I try to change or have to make a new design, it blocks me with this message: (Be careful! an error occurred that cannot be corrected. save the document, go out and relaunch toptron e)
I thank in advance anyone who can tell me something.
tree
if I don't go wrong version 7 dates back to 2003. on which version of windows did you install it? I would not exclude incompatibilities with the operating system. . .
tree
Are you sure it's version 7?
if it is so I think it is easier than it does not work than the contrary, too many different operating systems than when it was created, various updates etc.
I guess you're not paying and so you don't have any more assistance, but a phone call to a service center would do it, even if I have to say that I've been running out of service lately, and I have a bad feeling.
good morning and thank you for the answer, I'm almost certain that it is version 7 and it is installed on windows 2000 from 2005 and it always worked perfectly, but as I wrote the owner came to miss, and I fix a bit of files and folders, I don't want to have moved or deleted, inadvertently something, I repeat it all, just doesn't make changes, or does not create new designs, I wrote to the vertetron both mail and their forum, but I never responded.
good morning and thanks for the answer, I'm almost certain that it is version 7 and it is installed on windows 2000 from 2005 and it always worked perfectly ... fixing some files and folders, I would not have moved or deleted, inadvertently something,
moving files or folders do not think you can create problems like the one indicated, unless you do it in the c:\cimatron folder.
All the more it comes to think that after sixteen years the computer can have some connection.
may be a license problem, maybe the file that toptron reads for verification, or other similar things.
this you can see in the Start menu - 7.0-Top - Control Panel - Licenses - Licensing.
But if it was a license problem, I think it wouldn't even open the program.
I thank all for the answers, I repeat it is not an urgent thing, among other things today looking in the meanders I found the updates until 13, so calmly I will try to fix everything.
Hello, everyone. I have an old file modeled with 7.01 top that I would like to open and above all convert to .step to use....what can help me? ?
m.
