information about control fanuc 0m
  • Thread starter Thread starter LuisVito
LuisVito
Hello! Can any of you tell me if the fanuc 0m control is unable to handle processes that use x,y,z axes simultaneously (like trims on shaped molds)? if you, until what work feed can you get?
the control is mounted on a kafo vmc1100, with 24ut.,speed 9000 gir/min, year 1994-95.
the fanuc 0m works with the axes quoted simultaneously for here 3d movements.
personally I arrived at a f6000 without problems,
But I remember that at the machine's test, there was an additional card to be able to work with the high feed 0m.
I hope I've been helpful
Hello and thank you corsaro33! What car do you have? What year is it?
If you don't have the high speed, you lose your way back to the home of any year is the car..... .
My work center doesn't have high speed, but the way home I always found it! Just find the right compromise. . .
