Madda
Hello, everyone. I built a pro/engineering wildfire 4.0 assembly and defined the mechanism in such a way that through a table read from the outside the motor and screw connected to it rotate, and instead the transla cursor.
the problem is that when the animation starts, the slider leans on the frame(image 1), I would like it to be in the center (image 2). How can I do that?
Thank you so much!
Thank you so much!
