inserire coordinate x,y
  • Thread starter Thread starter GianNico
GianNico
Hello.
I should insert the quotation in coordinates of several points. using the "dimcoordinated" command I can insert a coordinate at a time or x or y. Is there a way to set the display of both coordinates in one measure?
Thank you very much
gng
or... .
the attached dwg consists of a point block, a qleader and 2 field, grouped as xy, place it in the drawing and after regenerating the quotas recalculate.
to move the coordinates, select the x grip, the rest adjusts itself.
bye
