inserire file shx in autocad lt 2012
  • Thread starter Thread starter kech
kech
hi...for work issues I have to insert in my design a file shape...premetto that I use autocad lt 2012....I vainly searched the command but I do not find it....previously I used audesk map in German version and with the command laden I was looking for the file shx and I inserted it quietly. ...probably the light version does not support this insertion?? ? ?
Thank you:redface::redface:
command charge charge to load it in the drawing
command shape to insert the previously loadedshx
I don't know if, however, in the lt version are present.
I thank you for the prompt response!! purtoppo in the light version the charge command does not exist....:mad:
