Rael84 Guest Apr 22, 2010 #1 Hi. use pro/e 4.0. Can you tell me if you can insert notes in sketch environment? Thank you.
Prof. Guest Apr 22, 2010 #2 Let me better understand what your need is, what do you need a note in the sketch? Bye.
Rael84 Guest Apr 22, 2010 #3 Prof. said: Let me better understand what your need is, what do you need a note in the sketch? Bye. Click to expand... I actually need a proe sketch to analyze some chains of tolerance and not to shape a piece. the note I just need to make the sketch clearer when I go to insert the image on a report
Prof. Guest Apr 22, 2010 #4 then use notes 3d. you see both outside and inside the sketch environment. or in the sketch you can use the command to write texts. It's a letter-shaped key. Bye.
