insert a dwg file inside another dwg
  • Thread starter Thread starter tecnodoff
tecnodoff
Good morning, I would like to know if it is possible to import/insert a dwg file previously created in a dwg design on which I am working without having to "copy-paste"... is a ke command allows me to do that?? ?
v explain with an example:
- I created a dwg file with a4 sheet format and I saved cn the word fa4.dwg
- I created another dwg where I created my plant, prospect sections etc etc. and at the time of the layout I would like to import/insert the a4 sheet previously created in the fa4.dwg file.
and possible to do this without "copy-paste"? ? ? ?
thanks to all
first a small search here or on google would not spoil!! !
command _xattach
insert it as an external reference. If that's the way you want to operate.
Sorry, planner. .
Why do you suggest xattach?
Maybe _insert does anyway to his case...
already done but inserts me a sort of "block" in light grey ke nn I can explode... .
Sorry, planner. .
I assumed that he wants to insert it as an external reference and not incorporate it into the current design.
Since you do not want to use a paste copy I thought about this option.
