Francesca Po
hi to everyone, I wanted to ask you if you know how to put a pane (rectangle) to an attribute (which is to indicate the code of the room in question). looking at the screenshot you will see a pane with the squares of the room and the other with the room code, I would like to associate that pane to the attribute, so when changing the length of the code also changes the length of the pane.
