insert all the same fixings in one shot
  • Thread starter Thread starter skia51
skia51
Hello everyone
I happened to use invetor2016 on the job. a function I found very comfortable is the automatic insertion of the same bolts in the corresponding holes. In practice I insert the bolt, nut washer etc., select the hole in which it will have to be inserted and the software not only suggests the diameter but places all the bolts in the equal holes, in a single stroke I fixed the fixings.
Is there a similar function in solidworks?
thanks to who will answer
Maybe with smart fasteners, but I never use them and so I don't know if it does.
However, if you have used the creation wizard holes or a repetition (linear, circular or sketch) in the axieme you can use the repetition from sketch o da series; if you have few holes you can use copy with couplings
thanks massive,
I usually use copy with couplings, longer procedure but I'm sure to have a completely defined set.
I'll try with smart fasteners, I didn't know about it.
thanks again and good work
if you do the details using the repetitions or, in case of screw holes, the drilling guided in the axieme you just need to use one of the two repetitions that I indicated in the previous message
according to me it is definitely better the repetition than to see to associate the same screw or bolt, always that the smart fasteners do it, to all the equal holes and having to tell him which one and what not; if models well the particular with a few clicks you have placed each group of vices
