donniebrasko
Can you tell me how I can save a jpeg in the cartouche with autocad so that it is visible to everyone?
thanks
thanks
preserve it intndi without losing references and without having to transmeter the jpeg algi file other?Can you tell me how I can save a jpeg in the cartouche with autocad so that it is visible to everyone?
thanks![]()
You have to do as I said above... open the image with editor any changes, select everything and then edit, copy then go to autocad edit, paste.I mean, anyone who opens that file on the other side can see all the contents.
I tried with the ole following this procedure
insert--> ole object--->creates from file
I have selected it but on my design it gives me a panel with on written the link where the image is located.
Am I wrong?![]()
After a thousand attempts I made it.I did as you say but unfortunately if I open the drawing on another pc I can not see the image I inserted.
Is there another solution?
thanks![]()
