insert body of the multibody part into separate materials
  • Thread starter Thread starter Giuno85
Giuno85
Good evening to all, I would have to ask a question.
I created an axis that contains several multibody parts.
In the multibody parts for working comfort are inserted screws with derived parts, which are subsequently processed.
is there any way to count the screws contained in the parts, using the distinct material with type only parts? ?
because in the other typology that is with re-entry, and detailed cutting is counted everything, both the multibody part and all the parts contained in the multibody, and it becomes problematic to use the distinct
the other parts of the multibody exclude them from the distinct. right button on the folder of the cut-off > excl.
or select the uninterested rows, even more than one at a time and not sequantial, right-click-line (hide selection if selected more than one row). this does not erase the rows, so they are recallable to the need, and maintains the sequential numerical order
thanks massive response, it is a great solution.
only that nn I had specified that by default in the company we use the distinct only parts, for convenience... I imagine from the answer you gave me that there is a function or option to activate to include a body of a separate multibody component?
Thanks again
could also work, if you could choose in a distinct only parts, which component to use for the "detail cut"
the only way to see elements of a multibody is the distinct indentation. That's the option.
what you don't care about exclude.
if you do not care for anything remove the separate cutting mode (delete the welding symbol that you find at the top of the functions); no separate cut no lines in separate rebound.
if you use a method by default and this is sometimes not good
I have never tried with the multibidy, but for example in the assemblies on the sceda configurations in a section you can tell him what to do for the child components, between the options there is promotes, this makes you that in distinct only with re-entry the assieme nn compaia but compaiano only the parts promoted to the upper level, maybe there is qlc of the genus on the multi body, but nn I have never noticed
