stef_design
Other problem:biggrin:
1 - I create a parallelepiped
2 - I create a cylinder with the option "up to the top" and select a face of the parallelepiped.
3 - insert, between prisma options, a 20 mm offset
4 - Right-click on the feature > insert into a new...
impossible!!! prism 2 refers to prism 1.(Figure 1)other way.
1 - I create a parallelepiped (the feature is called prisma 1)
2 - I create a cylinder (the feature is called prism 2)
3 - Right-click on the feature prisma 2 > insert in a new...
Okay, this is possible:finger:
4 - Now, I go inside the newly created body, double click on prisma 2
5 - published the properties of the prism, instead of "quota" put "up to the top" and an offset of 20 mm
6 - click ok(Figure 2)miracle
as never this behavior. first not and then yes?!? there is perhaps some option to activate
Thanks again
Thanks again
