insert jpeg!
  • Thread starter Thread starter uluwatu_74
uluwatu_74
salve...
sono estremamente pivello per quanto riguarda catia!
per cui...non riesco a inserire un jpeg applicato ad una superficie creata!
ho cercato nei comandi...ho applicato materiali...tentato di modificare...ma niente da fare!!!!
dove vado a parare????
:smile:
grazie 1000
Would I be curious to know how you did it?
in the sense that there are several... and you want to know which I fished?
or why don't you think I got there?
or (and maybe I should have done it before) why would it be fair to publish it? :smile:
cmq...I applied a material to the surface where I wanted to apply the jpeg... then... from the tree I modified the properties of the material going to spray in the window where various parameters apply. ..including the "trama"...if I'm not mistaken.
and there... unleave him the jpeg to insert... with so much transparency value to be attributed.
I hope to have been dignified clearly...and above all... having done it several days ago... I hope I wasn't wrong! ! !
after making changes in the properties - textures, having selected the desired jpeg, at confirmation nothing changes on the surface and the material remains the same.
aid
Mar
Strange.
I can only report you and remind you of some things:
1- are you in material mode in view ?
2- you set the texture uvs, the scale, plus the modes
application?
to the
I hope the images are more eloquent
of words
1-image 1-shading with material
point2- image 2 -signatures for uv mapping etc etc etc etc
to the
right luca-
you can use the tools of wordbench sketch tracer. .
but, in any way, to view the image you must be as "visualization" in material mode, even if you do not have to
apply no material to any entity-
to the
in addition to the sketch, which I use a lot, I had thought of another solution, suggested by the prof. of the noble on his book, but obviously I remember badly... I can't find her, so you're right.
