see3d
Hello I need a lisp that numbers the level curves because the lisp as autosez create the level curves without writing next to the quota number and I would need that. Is there such a lisp or any other remedy? Thank you:
the best remedy would be to use appropriate products such as autocad civil 3d :wink:...or any other remedy?
Hello, thank you, but I don't understand how to use this lisp you know? Plus the site you mentioned needs registration is by chance the explanation?long ago I found in this forum (if I was allowed to quote it? ) www.theswamp.org/index.php?topic=39644.0 the lisp I attach.
I'm so sorry, but I can't make it work, I have level curves, and I don't know where to go, there's a mini guide? :frown:Yes, for the non visible parts registration is required.
However, once the lisp is loaded, the comado lce asks you to give some points of passage that intersect the polylines, and then insert the texts of the quotas.
is part of the autolisp code in "labelcontourelevation.lsp"...you can steal clothes ...
