insert parameters into the part list
  • Thread starter Thread starter Crazy Fly
Crazy Fly
Hello everyone,
I wondered if with nx6 it is possible to insert parameters to the parts and then to make them appear in the part list of drawing of the together.
In practice I am making a tubular structure and I would like the part list of the assembly to be present also the dimensions of the tube (diameter, thickness and length).
I tried to search the forum, but with little result, maybe I used the wrong recerca criteria,
Can you help me?
Hello everyone,
Can you help me?
from nx3 to nx7 you should use this string in nx expressions:
"ug_setpartattrvalue("properties1",stringvalue(properties2)+" x "+stringvalue(properties3)+" x "+stringvalue(properties4)"
as it is not possible to associate with variable properties.
if you have to make changes and see them also in the updated part list you have to enter work part and make tool->expression.
from nx7.5 has changed in better, read what's new.
in addition to the excellent nx user tip I suggest you take a look at the routing module that all these things give you practically automatically without you having to turn on the attributes.
