Jan86
Hello, I need to automatically encode the blocks in a palette created by me. with a set of blocks already present (in the specific I talk about valves and tanks), when I transpose one on the model space, I open the card attributes where the first field is compiled automatically with the code already inserted in a progressive way (001 002 003 etc) recovering from the last code of the same object, while the other fields are to be inserted manually.I can't in any way do the same thing with the blocks created by me. In practice if I insert 3 valves of type 1 me it will automatically numera 1-2-3 , if change object must start again from 1 (example reservoir), if taking with the valves must start from 4.
