IronMike87
I am sorry first of all for the title perhaps unclear. . .
in pennies, I would like to create a design with the cartiglio of my company, inside which to insert drawings arrived from customers, suppliers or sister companies that are part of our own holding but obviously have other cards, other specifications, etc...
the main problem that I get is a bad quality of the image.
I initially tried with the simplest method of all: drag & drop file pdf.. immediately failed as sw required me to install adobe illustrator cs3
to which, quite confused, I tried to insert the pdf file from the taskbar using the input command. It works, too bad that doesn't display the whole design, but only a zoomed area. this also inserting the image into a sheet of size a0 and then increasing the display area to the maximum: I keep seeing only part of the whole design.
I tried to cheat.
>I copied the entire pdf with snap image in acrobat
> open paint
>>> > copy-paste the image to ridiculous resolutions (10'000 pixels long side)
>> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > e image image input image
so at least you see all, sin that you break out embarrassingly, especially when compared to the parts of the design that are "printed" by sw himself. Which I honestly don't know how to explain by counting the image resolution.
by curiosity I tried to insert the image into smaller carts, and continues to faint. So, I think there's some sw block.
for an operation I thought you could take me away 15-20 min, I lost half a morning like a pig.
Where am I wrong?
help me please
I tried to cheat.
> open paint
Where am I wrong?
help me please
