tanticapelli
Hello everyone
provided that I use the program especially for the creation of steel structures, coatings and similar.
in a set (I would say even quite small) I decided to try to insert bolt washers and dice to better quantify in the material count.
However, I find that the insertion of the toolbox objects is a rather slow operation in processing and not always the couplings are automatically set: I often happen that a bolt is coupled so concentric to the hole, but not with the under of the head corresponding to the surface below (usually a washer).
and anyway insert piece by piece with a certain processing slowness is exasperating also for modest sized structures.
I am wrong (as often happens...) or for the work that I have to do I insert the vines is not recommended?
so many hairs
so many hairs
