elfooscuro
Good evening,
Can someone give me advice on how to insert beams and pillars into the model and connect them to the masonry? They are in the learning phase, therefore they are at a basic level. so far I used only 2d autocad.
I inserted the pillars, beams and swabs. I then designed the backed ceiling with respect to the outer wire so that the insulating layer included in the buffer package goes to cover the outer edge of the same. the problem is that by using the joint command both in the plant and in the section (in this case by combining the insulation of the swab goes to cover the edge of the loft) it combines me with a mess.
I find the prospectuses with lines and holes.. .
