insertion point pastebloc
  • Thread starter Thread starter masfur
masfur
Morning.
I have this annoying problem.
I want to create a temporary lock in a drawing with the copy command.
select the objects concerned.
when typing the pastebloc command to insert the newly created block, the insertion point is very distant from the objects.
This causes me to insert the block into the... infinite space.
Is there anything you can do?
Morning.
evidently in the selection group there is an object that has its own element outside (very out) from the current screen, for example a block that has an invisible attribute, or a reference of a quota...
use the command copy puntob which explicitly requires the future insertion point of your temporary block
