installare autocad 2006 su windows 8.1
  • Thread starter Thread starter buzzo
buzzo
Hello, does anyone know if you can install autocad 2006 with w 8.1? I have to change cars but my boss didn't want to change autocad 2006.
Thank you all.
savior
theoretically not. maybe it installs but you may have problems related to malfunctions. autocad 2006 is not even more up-to-date.
Since on windows 7 I managed to install it and it works well, I hoped there was the way even on windows 8.1!
I said "theoretically." at your own risk. . .
as he writes tristan at your risk and danger
copy autocad installation cd to a folder
search for the setup.ini file
probably located
x:\bin\acadfeui\setup.ini
the content of that ini file is
where in red There are rows to be erased
[SETUP](PHP 4 = 4.1.0)
setup _ log =% temp%\ autocade 2006 setup.log
(PHP 4 = 4.1.0)
(PHP 4 = 4.1.0)
(PHP 4 = 4.1.0)
(PHP 4 = 4.1.0)
(PHP 4 = 4.1.0)
(PHP 4 = 4.1.0) dotnet dotnetsp1 mdac viewer flash acad
setup_startup_message=yes
[PREV_PRODUCT_IDS]
[MSI]
product_name=msi runtime 3.0
install_ignore_failure=no
install_cmd=msi\windowsinstaller-kb884016-v2-x86.exe
install_cmd_args=/quiet /norestart
install_platform=win32
install_upgrade=msi
install_minimal_version=3.0.3790.2538
[DOTNET]
product_name=.net framework runtime 1.1
install_cmd=support\dotnetfx\dotnetfx.exe
install_cmd_args=/q /c:"install /l /qb"
install_upgrade=.net
install_minimal_version=1.1.4322
[DOTNETLANG]
product_name=.net framework runtime 1.1 language pack
install_cmd=support\dotnetfx\lang\langpack.exe
install_cmd_args=/q:a /c:"inst /qb"
install_upgrade=.netlang
[DOTNETSP1]
product_name=.net framework runtime 1.1 sp1
install_cmd=support\dotnetfx\ndp1.1sp1-kb867460-x86.exe
install_cmd_args=/i /q
install_minimal_version=1.1.4322.2032
[MDAC]product_name=mdac 2.7
install_cmd=support\mdac_typ.exe
install_cmd_args=/q:a /c:"setup.exe /qnt"
install_ignore_failure=yes
install_upgrade=mdac
install_minimal_version=2.70
[ACAD]
product_name=autocad 2006
install_rollbackable=yes
install_cmd=acad.msi
install_cmd_args=/l*v %temp%\acadinstall.log
install_undo_cmd=acad.msi
install_undo_cmd_args=/qb!
install_hide_wrapper_ui=yes
[VIEWER]
product_name=autodesk dwf viewer
install_cmd=support\aev\dwfviewersetup.exe
install_cmd_args=/u2 /q2
[FLASH]product_name=flash
install_cmd=support\flash\silent install flash player 7 ax.exe
install_cmd_args=/q
there is no answer to the damages that the above can give to the pcs and more
if the installation can always run autocad as administrator, closing the various reports of windows errors.
I remember that autocad worked, only a few small problems on express, such as lisp, and something else I don't remember.
Obviously if you have applications on autocad 2006 as raster design 2006, this even if you install it will probably not work.
