insufficient memory. store data and exit
  • Thread starter Thread starter camula
camula
Good morning to all, as from title I have an insufficient memory problem.
I have already looked into existing discussions and the solutions found do not work. . .
I have a version 15.50.4.0 of cocreate modeling and I can't open a model in .igs format of almost 15 mb because the message "insufficient memory appears to me. store data and exit." I tried to restart the pc to "clean" the memory space occupied by the modeling and to increase to 4000 the memory-limit of the program but continues to give me the same error.
possible that it is not possible to open a model of such size?
thanks in advance to all for help and good work.
could depend on how the file was created
and also from some program
can you share it?
I'm sorry, but I'm not allowed to share the file... it is a total with parts of body shop... I asked the client to re-salve the file and re-send it...the problem however persists. .
send a simple part to test
pure a cylinder
usually what I don't open with a program I can open up with another
example with parasolids if you edit strings at the beginning of the file then it opens it without problems
Thank you, I tried to send the axieme "disassembled" into multiple files and, apparently, having dimensions less than the almost 15 mb of the previous one, I can open it. . .
But it seems absurd that it is not possible to open it directly, thus avoiding "reassemble" all the pieces...patience.
thanks anyway for the suggestions. good work at all
