interference toothed wheels
  • Thread starter Thread starter ciga00
ciga00
as you notice from the attached screenshot, interference occurs in gearing.
the values used are:
i=100 mm
z2=80
m = 2
pressure angle=20°
I do not understand where the problem is, since z min with pressure angle of 20° is 18 teeth
therefore consequently also a stl model exported from the same file would have the same problem?
on "export tooth form" there is some other option, but I never had to use it so I have no idea whether it is usable or not
non trovo la funzione esporta dente facendo clic destro sulla parte, ho inventor 2017
in the browser, select the toothed gears made with the component generator, right click -------- export tooth shape.
this until 2014, but I doubt that changes have been made to the component generator (it's equal for years)
However, I repeat, I have no idea if you can pull out the "real" geometry of the teeth or not
edit: always the same in 2018.... https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/cloudhelp/cloudhelp/2018/enu/inventor-help/files/guid-06a48c0a-62f6-4eba-9de0-49e2a13f2b15-htm.html?st=export tooth shape
Alternatively you can use kisssoft paid to get profiles in step format sufficiently finished really and made according to real manufacturing procedures with all parameters.
or there is free gear module on freecad 0.16/0.17 that realizes quite true tooth forms.
anyway cylindrical straight teeth wheel m=2, z1=20 z2=80 intersection a=100 processing tolerance din 3967 cd 25 He has no interference.
