internal filling of local areas
  • Thread starter Thread starter CAROLINA
CAROLINA
Hi I recently installed revit 2017.
I can't understand why, when I go to graphic visibility in areas and internal filling point I no longer see the blue sampling of the premises that in previous versions was displayed.
Can anyone help me??? thanks and a thousand
I lay this blue sampling in the premises if in the window vg areas - internal filling I no longer saw it was useful to check if the contours of the areas of the premises were perfectly closed and correct for the calculation of the area. Thank you.
that sampling usually comes out when you select the premises. . .sennò uses a color scheme
