GiGa
at very short I will have to do small renovations at home and being a new field (at least as a "main actor") I ask who is much more experienced than me...
In addition to other "minor" jobs, I would like to combine stay and entrance by removing the door and the tramezzo that divides them... but this would involve the presentation of the cila, if I didn't understand bad... what I think involves, between professional taxes and catasto, an economic outlay not indifferent in relation to the works to do... in this regard, some idea on how could it be a medium cost for such intervention?
to avoid is blessed cila, I could do without removing the girdle and simply create an opening (or an arch) removing the door that is now. now it is a door from approx. 100cm (on a plot of approx. 6mq) and I would like to widen it a little (top and maybe a little side).
I have read that no authorization is needed if, in case of enlargement doors, work is done
what I don't understand is until you can push back into the “modesta entity”: is there any parameter to be respected, in addition to keeping the two environments separated from this arc?“demolitions of modest entities, realization of closures or internal openings that do not change the distribution scheme of the real estate units and the building”
