in your design where the axis is located? horizontal or vertical?You need to change the sketch of detail.
View attachment 61318and then enter the odds normally... then you can change the arrows here:
Sorry if I wasn't clear, cmq in the drawing that attached deep70 there is a detail with the interrupted quotas. Maybe I didn't realize what odds he wants.in your design where the axis is located? horizontal or vertical?
What does it have to change the definition sketch area detail?
you made an example that is unclear
in your design you see a rectangle and without axis you do not understand how the diametric dimension is arranged.Sorry if I wasn't clear, cmq in the drawing that attached deep70 there is a detail with the interrupted quotas. Maybe I didn't realize what odds he wants.
yes exactly as it says massive, I understand that it is not something that is very used but as in this case it would fit perfectly. .in your design you see a rectangle and without axis you do not understand how the diametric dimension is arranged.
deep70 asks how to quote a diametral dimensiopne in the case of interrupted detail, i.e. a detail in which you do not see entirely the diameter and therefore it is not possible to quote by selecting the edges, as in the upper view of its image.
