umberto_89
Good morning, I'm doing an exercise. I made a rough (hidden), then a new body (finished). I should now carry out an intersection through lathe machining because later I should perform a turning operation. to do so you need the profile of the finished piece and I was explained that this can be obtained by intersection of the finished piece with the xy plan. When I go through the operation, I run into this problem. Can someone tell me how to fix it?
