intersections/delimitation surfaces
  • Thread starter Thread starter checco86
checco86
very kind users of nx
I wanted to ask you a further question: How can I "cut a surface" by another surface that intersects the first??? I put some pictures to understand the problem. the surface b, through the intersection with the surface a. of course the intersection will produce curves. the purpose is to fraction the surface b by intersection with the surface to and eliminate some parts that are needed. Thank you in advancesuperficie A.webp
I wanted to ask you a further question: How can I "cut a surface" by another surface that intersects the first??? I put some pictures to understand the problem. the surface b, through the intersection with the surface a. of course the intersection will produce curves. the purpose is to fraction the surface b by intersection with the surface to and eliminate some parts that are needed. Thank you in advanceView attachment 22603
trim body... to the "target" and b the "tool"
or, if you want to understand what happens, first intersect the 2 leotards and then make a trimmed sheet.
in nx7.5 the trim body between surfaces works (where possible) even if the tool does not completely intersect the target... a linear extension is made (be careful therefore... )
