Inv 2009, import step problem
  • Thread starter Thread starter Hole
Hole
Good morning to all,
I ask lumens to solve a problem in the shortest possible time.
I sent a file step of a particular from our supplier, it is quite detailed and full of surfaces. such a particular is made in
when I go to load I have no problem, but if I go to save the piece as a derived component some of its details cause me unclosed surface errors (see attachment).
What can I do to solve the problem?
even if I don't know inventor: as I first think about the level of precision with which the part was modeled.
made by the supplier that precision used (the default value of pro/e is 0,0012) and tries to set the same value for the new part of inventor in which it amounts the step.
don't ask me how I did it, but forcefully I managed to import the component. I attach the screen of the tree hoping you will understand how it was imported. among other things the particular turns out completely yellow and in the tendian material property appears to me "as color surface application". If I try to give it a color, the edges still remain yellow.
wait to rejoice!
If, in the table, you will need to pass a section line through the imported piece, it is likely that it will give you error.
Try it first.
what you imported is a surface, I recommend copying it to "construction" correcting errors and promoting it as solid.
