inv 2016 display in table dwg imported in part
  • Thread starter Thread starter Catafratto
Catafratto
I am inserting some machines in a lay-out and wanted to try a new "ability" of inventor 2016, that is the possibility of importing a dwg into an associate tenedole part, using it as "base" to build the plant: I'm not talking about the classic copy/paste in a sketch or stuff like that.
everything was going well - the association works, I can bind myself, the import of the bodily quick lay-out... I mean, at least like that, it seemed until the time to put on the table.
my purpose was to save me a passage by making the table with schematic lay/out + machines done well in a solution: the old system was to make a table with view from above for each machine, to export to dwg, to create blocks to insert into the lay-out. However I can not find way to display imported dwg at the table, including geometries / get sketches pattern have no effect; if I create a sketch and I will project the geometry of the imported dwg (with the new specific projection command for the purpose) I will update the problem, but the lay-out is too big because it is worth it.
I lost something? Can't you see? What a paxxe!
and above all, who knows how to do, if you can do it?
thank you all in advance!
You got me curious and I did a flight test and very fast. . and I will tell you that even projecting the geometry of the dwg connected in a sketch, this geometry is not seen at the table... only that part of the dwg, because if you draw with the usual inventor comnads, type lines or circles within the same sketch, these are seen...
I have tried again, I understand less and less: the first times I happened what described by the Ilario, then began to display on the table also the projections of the dwg... I don't think I did anything special in the middle.
Boh!
It works to me, if I project geometry in a sketch, he sees it quietly at the table
I have a question about importing dwg.
If I amount a dwg and the view is mirrored as I can mirror it with the convert of the import dwg?
I have already found a solution, that is to reverse the perpendicular of the plan associated with the dwg, but this is a little uncomfortable especially if the dwg is associated with the plans of origin, to which the perpendicular cannot be reversed.
You have a better procedure, don't I?
