hi to all, I would like to know if it is possible to have the old interface of inventor 2009 also on 2010 and later. and if yes, how do you set up?
advice: already used to the ribbon, the next versions will always continue in such direction, remain anchored to the classic interface does not need. also because there will be no more possibility, in a simple way, to set the classic interface.
so much it is worth making a little effort and getting used already. You'll see it's not bad.
