User1
Now I see what I can do. Give me a few days. However, he has nothing special!
you are a great!!! I didn't think about it!animated the angular bond ^_^
p.s. you must also put them in contact group
we know how to use it, only that the utility in terms of use is really equal to 0.01%. I think stefano meant they could do it better.Now I see what I can do. Give me a few days. However, he has nothing special!
I would use it intensively, in the plants we make we must check the areas occupied by the load in the curves of the path.In fact, it's a perfect match!
...only that utility in terms of use is really equal to 0.01%....
remains a complex animation, because inventor must calculate the path as the component follows it. so if you have complex assemblies, maybe aactivity and pc not very performant you can not do much. the aid in question is simple but if you have more connected parts iventor you c..a on! !I would use it intensively, in the plants we make we must check the areas occupied by the load in the curves of the path.
even with the contact group I never managed to get a useful result.
we take refuge in corner doing it with autocad step by step (which boto !! ) )
Ciao.
