inventor 2011: bugs... ?
  • Thread starter Thread starter MauroTC
MauroTC
Hello.
I am currently working with the 2011 version and this I wanted to report in this post what for me are anomalies that I do not explain; then I do not know if to define them (impropriately) bugs or if they are things that have their technical motivation... (maybe someone is inherited from previous versions... ? )
Of course if there are others you can agree (maybe other reports are scattered around the forum; here could you make a collection? ).
1) in idw I can no longer drag the quota extension lines on axles and center lines.
until the 2009 version (the last used before this 2011), I remember very well that if I wanted to change a point of origin of the "stacco" of a quota, I could click and drag with the mouse the green pallino on the new reference, whether it was edge, whether it was a reference axis or hole center. now with 2011 it only allows me to give new edges, while if I move on a board it gives me error (points not associated with geometry) and I am therefore forced to cancel it and put it back on top.
2) central point on non-real idw.
I have a set of which I have two different assembly modes, one general and one for transport, where some parts are disassembled out of shape.
I did two different levels of detail, one "standard" and the other "for transport". all right here; If I interrupt the assist by asking him the center of gravity, he will show it to me in the two different positions. making the table, representing once with the view of "standard" detail and on other view the level of detail "for transport" and asking in these the representation of the centerpiece, always displays it at the same point (as in the standard version to understand us, the one where the parts are present).
Is it just me?
Thank you. .
classic question: do you have service packs?
He did it to me before maintenance.
Bye.
Ni!
you are right, I did not specify the update status of my program (at sp1) as well as I did not specify the version of s.o.: xp 64 bit.
So knowing that strangely I had dumped both sp1 and 2, but installed there was only 1!
updated with the 2 problem 1 no longer exists (drawing quotas on boards), while the 2 remains, that of the center on idw.
Hi, I'm a new user. I joined the forum to receive help on some things of the inventor professional program 2011. how can I put the project in motion?
