inventor and mechanical installation problems
  • Thread starter Thread starter AngeloB
AngeloB
Hello everyone
I have this problem and the autodesk latita assistance:
-I have a pc with xp pro 32 bits
- work without problems with autocad lt2007, regularly fired
buy inventor suite 2010 new with a completely different license from that of autocadlt
-inventor2010 installs without problems
-mechanical2010 continues to remain in "demo" mode
-lt2007 continues to work smoothly
in a rage raptus hò already uninstalled everything, but thinking about the problem could be in the version of lt2007 that there is a different license.
Could it be?
Did you contact autodesk assistance?
In any case, you can try a few things that have solved me a similar situation:
solution to:
control panel, internet options, advanced card, protection, deselections the author’s certificates check box.
restart autocad.
b solution:
remove the file (rename without deleting it):
c:\documents and settings\all users\application data\flexnet\adskflex_xxxxxxxxx_tsf.data
restart autocad
thank you for the help, but now it seems to work all, even if the inv start and mech. is very slow compared to lt.
hò uninstalled only mech. and then reinstalled it by entering the license and the product code. now everything works and I came out of the "demo" mode
I do some experiment and then try to install algor2011
Hello and thank you
