inventor design chain rings
  • Thread starter Thread starter lucafer117
lucafer117
Is it possible to draw a chain of rings? Is it better that the driving spline is adaptive to constraints?
try reading some past discussions: you have to decide whether to do a single part or together, do some tests and let us know where you don't understand the situation
Thanks for the info, but I didn't want to do everything I'm around for a piece of chain. It seems strange to me that the last inventors do not have this command.. .
There is no "ring chain control" in the centre.
You have to draw it, then as I have already told you decide whether to do a unique part or a set with all chain rings. I have linked you old discussions to make you understand the procedures and concepts, then if you look for the easy solution I am sorry but I am of the notice that users should a minimum apply to then expose doubts or clarifications in the procedures of realization.
for example in the content center there is a module for the transmission chains, but the single jerseys are not drawn but simply a solid that replicates the encumbrance of the same chain, so if you want to have the individual jerseys it is still a construction that you have to do independently with the procedures that I have linked you above.
inventor is a great program, but with monstrous elementary gaps, for the cost he has. In fact, you linked me with artifacts that were done with inventor 2008, that of 2024 in my opinion should do the chips as well:)
look that the "artifizi" as you call them are currently used for various uses, even in the most recent versions. the beautiful or the ugly inventor is that there are no unique ways to get to the goal but different equally satisfying solutions.
for 20 years I use inventor and ring chains used them 3 times, once I made the first model and banged our head at least 10 minutes then the next time you find yourself with the job almost done. for how you answer I guess you don't even want to understand the logic of running some software concepts but simply look for the quick solution to your problem and maybe already the 3d model ready for your use.
from my modest point of view, it must be remembered that the technical design must be schematic, it must pass the concept in the best way. It's not an artistic design.
Do you really need the chain block with all your rings? or is there sufficient a scheme of encumbrance?
uploading the software of all the mathematics necessary for that type of representation makes a really heavy design (we are not using a video game graphics program).
Then the day the software will do everything by itself, we will change jobs that we will become useless.
