Manuel6d
Hello, I am attending a training course in technical design and mechanical design.
I am trying to learn inventor also independently and I realized that the tutorial guides in some cases do not reflect what I can really try.
for example starting from this link:
http://help.autodesk.com/view/invntor/2014/ita/?guid=guid-c9d795db-83dd-4460-9132-d3374b9e728ftells me to copy a certain folder from files>arbor press tutorials but this folder in this version does not seem to exist.
in fact the actual path of the exercise folder sends back to the folder: "interactive tutorial" where obviously does not exist as above.
I also tried to install the exercises available on the autodesk site, now I can't give you the link because they are on another system. He saved them in a sample folder. Actually, I don't know how to use them. I'll see later.
in a few words, I would like to follow that guide, but it is not accurate based on the program I am using...it will be very likely that I will find other similar problems following the guide.
Do you have any solutions? apart from the obvious to do with what you have
