inventor for beginners
  • Thread starter Thread starter pietro46
pietro46
I propose this post to post tutorial thought for industrial machinery construction.
the versions used will be: inventor 2009,2010,2011. for the moment my programs are all in tedesco Naturallye cercherWhat? di write in Italian :finger:
good 7+:biggrin::biggrin:
View attachment 3D.zipgreat stefanobruno I think together we will be able to write some tutorials.
in the files there are some of my designs maybe 10-20% I created with inventor.
now I should beh)choose one to start writing the tutorial for beginners, you which would choose, tonight ne invio some + beautiful.
I am showing what ad ora ho creato, if a someone likes something just ask, 90% are also listed. (?)
the purpose è to choose the cute piü and we will make some tutorialsView attachment 3d.i.zip
Great! ! !big guys, I put you this tutorial that is on you tube, just type, inventor autodesk tutorial part01 - italian is the first tutorial
ps. I would add even if someone has some design or design to give us can post it here so we can try to reproduce it:finger:. Thank you.
bye,
I fully subscribe to what is said by Pompeo79.
If I may suggest: Some of your work deserves to be shared on grabcad.
bye:
my goal is to do it 100% in Italian, the problem to solve is that I can't find the pachetto of the Italian language to ensure that even my inv. become ita. without deteriorating the German part.
Maybe the best thing is that he writes to autodesk.
in the past I did some tests, I installed the vers.2009 and then also 2010 and 2009 did not work +. instead autocad mechanical does not make whims.
can you install + version at the same time? If so what should I do?
3 later versions can be installed simultaneously.
I also have problems having more versions, I have now resigned.
in the morning my opening sequence is: open inv 2009, close and open 2011.
if I don't do so, not part of the 2011 rel.
on one side I am tempted to leave only the last rel., on the other I am afraid to lose the chance to start it even with that "procedura".
I'm afraid I've misunderstood your question, you want to have two identical versions but with different language, don't you?
two identical releases same language from strong issues at register level. much more serious than having more annual releases.(Finally only a nuisance)
the package in Italian does not exist. only Italian release 32 and 64 bit
if you could add only the languace pak was brilliant.
otherwise I try as you said, I installed inv. 2010 in Italian and I do not uninstall 2011 .
hem apologized if I didn't introduce myself, but I'm just a "reader" of the forum (also because I'm not an engineer, technical and or mechanical designer etc., but only a small worker curious to understand how the "own" working on the sheet), and as I'm interested in the discussion I wanted to propose to pietro46 that to avoid the problem of the register files that maybe go into conflict by installing more versions of the same software on the same operating system, can install http://www.virtualbox.org/, so you can install many inventors 2011 in different languages until there is room on the hard disk.
Well, I've tried all of them, and I'm reassigning myself, a pc a release. nothing 2011, only 2010 Italian and tedescho.
load here as the gear planetary version pack an go was asked
and since I am currently studying the constraints with animation I also place my motor 4 times, made it together with this guide http://www.ingenieurbuero-schlieder.de/ if it were the desmosedic gp 11 ahahah, maybe
Well, in the past, I had created some nice pistons and a pair of twins.
sin I couldn't load anything the site doesn't charge me, maybe because and Sunday ahahah
are of a height between 12-13 mb
try using a site to upload as a megaupload.
In fact it is difficult to put so heavy attachments here.
to overcome the registry file problem that may conflict by installing multiple versions of the same software on the same machine, it can install a "emulator" operating system i.e. multiple independent operating systems (even the same ones,) on the same pc using this software http://www.virtualbox.org/, so you can install many inventors 2011 in different languages until there is room on the hard disk.[/QUOTE].
I have installed virtualbox, I've stalled in a 20 giga partition, so far everything goes well so the problem is how I have to proceed how much install the 2012 version x make it that does not damage the release 2010
to what should I be careful? :confused:
ops excuse the delay of the answer!
then you installed a new virtual machine by assigning 20 giga of space, a bit of ram and you "said" that operating system you will install above.
Now you should run the first start procedure, i.e. I try to explain that "virtual machine" you must treat it as if it were a separate computer, new and without operating system installed above, then enter the cd of the operating system that you will go to install it and press the start button, should start the setup and you will have to proceed as if it were a normal "first computer configuration" will not minimally interfere with your "real machine" i.e.
Unfortunately I am poor in explaining things, but in poor words and how to have a "computer" and if you can have several (until there is space in the hard disk) and with different operating systems installed inside and with 32 or 64 bit architectures.
p.s. during the first start procedure should ask you the drive letter of your cd-rom reader remembered to set it.
I did everything as you said and now install xp prof.why occupies pocho space, then the other programs, pecchato that inventor 2012 does not yet exist in Italian. virtual box and in ted. and not difficult to use it, the problem was that I of virtual machines never heard of it, and I didn't trust so much, I think I made the right choice, deltronde was the only solution about my problem
Thanks again and good Easter to all
good evening to all,sorry if I intrometto ,I would like to know it is possible to save files from inventor 2012 in inventor 2011 ,I don't know how to do. .
Thank you.... good night at all:)
