inventor: how to smooth a edge
  • Thread starter Thread starter Cavillo
Cavillo
Hello everyone:
I have been using for a few days inventor 2015, I have to bevel the edges of a cube, but only the tips that form at the intersection of three sides
but I don't find a proper command. the bevel command makes the bevels but on the corners that form from two faces, unless there is to set it in a way that I cannot find.
cable
I never needed to do that kind of workmanship, but I don't think there is a special command, I think the only solution is to create a sketch on a tilted plane and remove the "point" with an extrusion
create a sketch on a floor that passes from the center of your nut; at the right distance from the center, then do "revolution" (with export) and you made your bevel.
