guyver
Hello I would like some clarifications on inventor lt.
premise
The project I was talking about some time ago is leaving.. .
so I would like to look for a "rigorous" cad to be alongside rhino
I would like to understand what are the limitations of inventor lt that seen its cost, about 1700 € in suites with autocad lt, is very attractive. . .
I design for the stone industry therefore, as I said, a typical work can be the helical handrail, conscientious etc.
I would typically draw all the handrail from floor to floor and then I would need to divide it into several pieces (to change then to put them in cnc) to produce.. .
Is it possible to share a part with you or is it considered together?
can you model multiple objects in the same part? example: handrail and conscientious in the same design
what is the modeling sheet (sheet metal) that lt does not have? Are there important features?
for other missing features (fea, tube, cable etc.) I would not miss it by using them... .
is the trial version of inv lt complete in all its functions?
then there would be the speech cam 5 axes but it is another speech for now.. :smile:
premise
