inventor on 2 monitors
  • Thread starter Thread starter chiocciolina81
chiocciolina81
Hi, everybody, I'm sorry to ask for information. I connected an external monitor to a laptop. I would like to be able to open a collection file of inventor 2012 and a particular each on a different monitor so that changing the one can see in real time changes on the other file.
Is this possible?
Moreover, I ask if you can do so to resize the windows each within your monitor without having to resize them by hand so, of course, not accurate.
I thank anyone who can help me.
I also use 2 monitors for convenience. But I think you should open 2 inventors and keep them each in a monitor. Alternatively, open only one and, by hand, extend the main window in both monitors.
However, it is updated when, modified the component, click on any part of the axieme to make it active.
Thank you, then I try so... .
and as for window resize, don't you know if there is any setting to make sure they fit the monitor?
working with two inventors open on the same project you can do but requires attention, you need to know exactly what you are doing.
I work with 2 monitors systematically and use only one inventor with open multiple files more often.
I use the two inventors by consulting one without ever saving and acting on the other actively.
with two inventors the windows are perfectly managed, with one you have to think about it from time to time, there is no automatism.
I also use more often 1 open inventor, even because 2 seem to me a little heavier to make jars.... :
interesting... but I have productstream and does not let me access with the second instance of inventor:( ... tricks?
