ipart e vincoli
  • Thread starter Thread starter atonucci
atonucci
hello to all
I've been working with inventor 2015 for a few months and I'm using iparts. I ask you why when I turn a part into ipart and replace the generic with an element of the family I lose all the constraints of the component.
tree
the generic part file you mean the factory??
If you speak together, you do not enter the factory, but directly a member, then you do not lose anything,
if you want you can manage imates too.
if you have already entered the normal part in the whole and then turn it into iparts, and after you make him calculate another member,
then you operate a replacement of real files.
Hello eugenesis
What I meant is the second part of your answer.
I have done a set and some parts have turned them into iparts but when I replace the initial end with an element of the family belonging to the same file that in the meantime I turned it into ipart I lose the constraints that bind the part replaced with the other elements of the axieme.
How can I avoid this?
In fact, as I said, you have a replacement of files and then you lose the constraints that are anchored to the ids of the selected faces!
At this point, it works with imates and everything stays deceased, otherwise it changes your workflow.
insert only members
