ipart together
  • Thread starter Thread starter Ing.filippo
Ing.filippo
I'm new to the forum. I can't find a solution to my problem.
I created an ipart with so many different sizes. I need to import it into a set so that all the different types of iparts are generated automatically in the axieme and not selecting each time the different sizes and then inserting the model.
I think it's pretty simple as a solution but I couldn't get any results so far.
when you realize the new ipart, you can select the table and with the dx key select "genera file"
This creates a subfolder in the directory where the ipart resides, where it saves all the derived parts generated.
then you can insert all files from the destination axieme at the same time by running a multiple or "drag&drop" selection of all files to explore Windows resources
I found this solution and it works. I was wondering if there was an automatism to improve this process, thus avoiding these steps. is the only solution in the programming of an ilogic rule according to you?
and would it be possible to change the part directly into the axieme with iassembly, according to the same parameters and method of the ipart? and then generate so many parts automatically in the axieme?
Sure, if you insert a iassembly into a set, just select the table from the browser from the axieme where you entered it and with the dx key select _foto__220.webp
