iproperties and cartilage
deep70
Hello everyone,
I have the need to insert the value of the unquoted bevels on the relative field of the cartiglio, but after several attempts the thing does not succeed, all other entries by filling the properties are ok except for the item <<smussi>>.
I press that the cartilage is not mine, and that therefore I did not do it, I tried to remake the connection in the cartilage (always that the procedure that between the other place below is correct).
I can't in particular put the value in the closing window in image 3 as the "smussi" voice does not appear.
I'm not familiar with inventor.
</smussi>INFO.webpINFO2.webpINFO3.webp
solved everything,
just fill out the properties when opening sheet format
INFO4.webpThank you all.
Cartridge points to a custom i-properties of the drawing, the value you have to insert from the mask of the i-properties of the table.
in the list of custom i-properties (I imagine both model 3d) the bevel voice is not there.
In fact, I also tried to add it both in the model and in the drawing, but nothing did not appear, then opening the drawing format at first I saw the list of entries, I inserted the value and appeared in the cart.
but I can do this at the beginning, drawing in progress I am point to head.. Maybe I'm wrong.
is the fact that the only one who succeeds me is to insert the voice at the beginning in the phase of choice and opening of the sheet format.
Browser.webpin the browser, expand the cartiglio, text field.
Still, there's something wrong with you, "checked revision 2" and insert the value of the bevels?
