Piron88
Good morning, everyone. I have a problem with autocad architecture 2009.
I press that in my pc I also installed the 2010 and 2012 version and that I have the active subscription and I have windows xp sp 3 32 bits.
I installed 2009 and at the first start I gave " activate the license " (the only selectable option)
The following error appears to me:
"errore irreversibile : untreated e06d7363h exception at 7c812afbh "I tried to uninstall aca 2009 with the use of programs that thoroughly remove applications including entries in the registry (revo uninstaller ). reinstall the whole, but same result, irreversible error (equal to the previous )
I tried to do a google search, the same identical error is found by many users in software other than aca 2009, in particular autocad 2010, and the only solution suggested by autodesk forums (but also in general ) is to change values in the registry system
http://forums.autodesk.com/t5/autocad-2010/fatal-error-unhandled-e06d7363h-exception-at-7c812afbh/td-p/2576143I tried with the solution suggested by autodesk (in the folder corresponding to the software in question ), but the values were set as a suggestion.
Can anyone give me a tip?
